Aug 26, 2025 1:10 AM UTC
STPSC10H12G-TR Replacement
STPSC10H12G-TR is used in our projects, it's NRND and may be going to EOL.
Do you have recommended replacement for this part?
Thanks!
Aug 26, 2025 2:18 AM UTC
STPSC10H12G2-TR,STPSC10H12G2Y-TR,STPSC10H12GY-TR,SICRB101200
CeciliaAuthor
Aug 26, 2025 2:26 AM UTC
Both STPSC10H12G2-TR and STPSC10H12GY-TR are also NRND.
What's the difference between STPSC10H12G-TR and STPSC10H12G2Y-TR except automotive?
The package of STPSC10H12G2Y-TR is D2PAK HV, what's the difference compared with D2PAK?
Peter BENSCH
Aug 26, 2025 4:19 PM UTC
@Cecilia You have also opened a ticket in the Online Support OLS under ticket no 00241995, where you will get an answer.
/Peter
CeciliaAuthor
Aug 29, 2025 6:47 AM UTC
Hi Peter,
I haven't get feedback about this case yest, can you help take care of it? Thanks!
Peter BENSCH
Aug 29, 2025 7:00 AM UTC
I have no influence on the processing speed of OLS tickets, so I kindly ask for your patience.
What I can say, however, is that the D2PAK HV has slightly greater air and creepage distances than the conventional D2PAK, making it more suitable for high-voltage applications.
/Peter
