Jun 25, 2024 1:34 AM UTC
STPM32+XZM-CT50A01
I'm trying to use STPM32 with XZM-CT50A01, and the series resistor = 6.2 ohm.
I thought ks = Rb/N = 6.2/1000. But I cannot measure the expected current.
The load was 50mA but STPM32 respond 1.2A.
The software may be OK because we have confirmed with EVALSTPM33.
I'd like to know the Ks setting is correct or not. Maybe our board has already damaged, or the board has cold soldering??
Can you advise me if the Ks calculation is correct?
DaichiBest answer
Jun 25, 2024 10:51 AM UTC
I solved by myself.
[Cause]
Gain setting was wrong. We have to set GAIN1=x2 (0x0) but we used default = x16(0x3).
We missed the default parameter.
Once we set to correct gain (x2), we were able to measure reasonable current.
Thank you
DaichiAuthorBest answer
I solved by myself.
[Cause]
Thank you
Andrew Neil
Jun 25, 2024 11:12 AM UTC
@Daichi wrote:
I solved by myself.
Excellent!
Now please mark that post as the solution.
