Mar 17, 2024 12:48 PM UTC
STPM32 for 0.2 class metering
Is there a solution to use PCB based Rogowski coil with STPM33 from 200 mA to 200 A with 0.2 Class Metering accuracy as per ANSI C12.20
Billy OWEN
Mar 19, 2024 4:32 PM UTC
Hi @Harish203
The forum moderator had marked your post as needing a little more investigation and direct support. An online support case has been created on your behalf, please stand by for just a moment and you will hear from us.
Regards,
Billy
