JeffThompson
May 12, 2022 11:50 AM UTC
STPD01 Configuration After EN or Vout Change
It looks like I need to write ILIM after making a change to Vout unless I want the default value for 500 mA. I didn't see this mentioned in the datasheet. Are any other settings affected by changing Vout? What about de-asserting and re-asserting the EN pin—do I need to reconfigure anything for which I do not want the default value?
