irmakci
Nov 26, 2010 10:19 PM UTC
stm32 sensorless 24v brushed dc motor control
Posted on November 26, 2010 at 23:19
irmakci
irmakciAuthor
May 17, 2011 8:20 AM UTC
Posted on May 17, 2011 at 10:20
any answer?
irmakci
irmakciAuthor
And also how can i find FOC GUI software?. I downloaded for along time ago. But it is not available any more?on ST site.
bille.stello
FOC GUI refers to sensorless control of brush-less BLDC motor. Is that what you ment?
By the way, it's still on the web, you can find it for instance at
http://www.st.com/internet/mcu/product/164495.jsp
Regards,
Billino
muratterzi2
first off all you must use single pwm channel to drive power mosfet with a mosfet predriver. ifyou want control direction another output pin can be arranged for direction information. in that case you must use a hbridge dc motor power circuitry.if you want control mmotor torque adaptively you can add a resistor between ground and mosfet. and you connect that pin wit a suitable current sense amplifier circuitry to adc input of mcu. you ccan change pwm freq according to current across on motor.
there a a lot of simple aplication codes at section examples library adc and pwm. you can adapt that codes for your aplication.
