SDawn.1
June 30, 2020
STM-PLC bug8
  • June 30, 2020
  • 0 replies
  • 535 views
URL:
https://www.st.com/content/st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32-ode-function-pack-sw/fp-ind-plcwifi1.html
Type:
Buffer overflow
Description:
The variable component_index is used as an index for accessing the array Component and will increase with many operations for example the code snippet as shown in line 337 of Ladder_Lib.c. It may lead to a buffer overflow without checking the availability of the index component_index when accessing the array Component as shown in line 421 of Ladder_Lib.c.
108
uint8_t Component[512];
236
int16_t WiFi_Decode (uint8_t* frame)
237
337
Component[component_index++]=decode;
421
Component[component_index]='#';
429
Result: Memory corruption
