Jan 14, 2026 8:33 PM UTC
STEVAL-WLC89TRX Information
We currently use the WLC38, but wish to use the WLC89. Our sales provided the full datasheet, and is ordering samples of the STWL89 for us. However, there are no more evaluation kits available.
Can the eval board reference design files and/or gerber files be provided?
I saw the Wireless Charging solution Wiki post but the WLC89 is not there.
Jan 16, 2026 7:38 PM UTC
Also, where can one get the code for the WLC89?
Previously, the code for the WLC38 and other chipset was made available on GitHub, but that repo is no longer available.
Didier HERROUIN
Jan 20, 2026 1:26 PM UTC
Dear WirelessAether,
About wireless charging projects, ST has decided to reduce the mass market support.
Your distributor is supposed to help you for chipset selection and eval kit procurement.
Please open a case on st.com (https://www.st.com/content/st_com/en/support/support-home.html#), you ticket should be re-directed to me and I will be able to support you directly.
Best regards,
Didier Herrouin
