Mar 3, 2025 10:58 PM UTC
STEVAL STWBC86TX programming
Hello, I'm developing a wireless charger based on the STEVAL-STWBC86TX. When designing a new PCB based on the evaluation board, would it be possible to use the I2C converter of the STEVAL-STWBC86TX by removing the jumpers in order to program the new PCB?
Mar 9, 2025 1:52 AM UTC
Hi Deiver
Yes you can remove jumper and use for new pcb board to download fw.
also you can use MCU to download fw
Mcu C drive code:
GitHub - STMicroelectronics/STWirelessCharging-C-Drivers: Standard C platform-independent drivers for wireless charging ICs
