Peter BENSCH
Peter BENSCHBest answer
Apr 8, 2024 7:05 AM UTC
Well, the data sheet, section 6.1 describes how VEOC is set with a voltage divider R4, R5, R6. The same designations of the resistors can also be found in AN4397, where the equations 12...14 in section 4.3.3 only have to be rearranged according to the required resistance (VBG = Bandgap Reference Voltage = typ 1.23V).
/Peter
Peter BENSCH
/Peter
rsmquAuthor
Apr 8, 2024 10:03 AM UTC
Can you share me a schematic diagram to make the VEOC up to 5.3V?
Peter BENSCH
Apr 8, 2024 7:19 PM UTC
The schematic for this is identical to a smaller VEOC, only the resistors R4, R5 and R6 have to be adapted. Please read the sections mentioned in the data sheet and AN4397 and try to transform the equations.
/Peter
