gianluigi
May 17, 2011 8:15 AM UTC
Posted on May 17, 2011 at 10:15
I have a Draft version of the package related to the STEVAL-IHM015V1 kit.
You can try to use it and let me know.
Best Regards
Gigi
external
externalAuthor
Good Afternoon,
I have a STEVAL-IHM015V1 and I am trying to control a sensorless BLDC application.
But I cannot find the LV ST7MC GUI specific software for this board. The cd I have received had only the RDK GUI for the ControlBD-7FMC2 that have the option of three diferent power board.
Does anyone know a ST7MC GUI that I can use with this board? I also have found the STEVAL-IHM017V1 gui that seems compatible, but I am still concerned with current limitation problems..
Thank you
external
externalAuthor
I have used your draft version for this package. It works very well, but i can not supply more than 4 A to my motor. I have checked the resistors and the GUI configuration. It should allow me supply at least 7 Amps.
Do you know if there is another limitation in this version of software, besides the ones that we set with the GUI software (files:version.h and MTC_Sensorless.h).
Thanks.
Best Regards
Gigi
external
externalAuthor
I have used it today and it worked.
Thank you !!
But i got a problem with current limitation, I had changed it to 8 Amps in the software. But I wasn't allowed during the test to pass 4 amps.
Thanks.
external
externalAuthor
I'll try to use it today and I ll tell about it.
Thank you very much!!
Best Regards,
Eduardo
