RBerw.1
Jun 15, 2020 3:40 PM UTC
STEF05: What is the minimum time En/Fault must be held low to reset the device?
Peter BENSCH
Jun 16, 2020 12:59 PM UTC
Usually you would reset the STEF05 using e.g. a MOSFET, as shown in the datasheet, fig. 4.
The datasheet gives a recommendation how to handle the Enable/Fault pin (section 5.4): "[...]the device can be reset either by cycling the supply voltage or by pulling down the Enable pin below the Vil threshold and then releasing it."
The datasheet also contains the value of Vil.
/Peter
RBerw.1
RBerw.1Author
Jun 16, 2020 2:18 PM UTC
Just to confirm; There is no minimum timing, reset occurs immediately when Enable/Fault is pulled below Vil?
Peter BENSCH
Jun 16, 2020 3:10 PM UTC
Correct.
