ALomb
Senior
Mar 2, 2021 9:24 AM UTC
STC3117 system integration
Application note AN4870 (architecture overview) refers to "Charger IC" connected to microcontroller via I2C and to STC3117 via CD.
Can you indicate a suitable Charger IC ?
My project is a "true" capacity tester for single Li-Ion cell (18650). Do you think the STC3117 is a correct choice?
Winfred LU
Mar 5, 2021 5:26 AM UTC
STC3117 is a gas gauge IC.
For charger IC, you may consider STBC02, STBC03, STBC08 based on the charging current.
ALomb
ALombAuthor
Senior
Mar 6, 2021 9:36 AM UTC
@Winfred LU​ ,
the MIKROE-3049 board (from ST site) uses STBC08 and STC3100.
My question is: can I use it to make a battery capacity tester ?
My intention is to add an electronic load for the discharge phase. A microcontroller (for example a STM32G0) manages the charging and discharging phases and read from STC3100 the data.
Otherwise, as described @Gregory Go.​ in STC3117_vs_STC3115_comparison, I could use the pair STC3115 and RT9532 (MIKROE-3741 and MIKROE-3748) ?
I would like to assemble the necessary hardware with ready-to-use boards and do the software development first.
Winfred LU
Mar 8, 2021 1:56 AM UTC
Yes you can.
For battery monitoring (gas gauge), STC3100, STC3115, or STC3117 can be used.
For battery charging, STBC02, STBC03, or STBC08 can be used.
MIKROE-3049 board (Charger 2 click) can be a good start.
The product is made by the ST's partner, and the software package is also supported.
https://www.mikroe.com/charger-2-click
