msz
Apr 9, 2021 2:12 PM UTC
STC3117: SOC level of Ri referred to by datasheet
For calculating the VM_CNF value the datasheet of the STC3117 gives the follwoing equation:
VM_CNF = Ri * Cnom / 977.78,
where Ri is the impedance of the cell.
The impedance of the cell however depends on the SOC, so i wonder at which SOC the Ri is supposed to be measured for use with this equation.
Any ideas?
Winfred LU
Apr 12, 2021 7:30 AM UTC
It would be the initial resistance measured at 50% SOC.
msz
mszAuthor
Apr 12, 2021 7:34 AM UTC
Hello Mr. Lu,
thanks for Your quick response.
measured at 1kHz sine i assume?
kind regards,
Winfred LU
Apr 12, 2021 7:39 AM UTC
Yes, the resistance is measured at AC 1kHz 50% SOC.
The value is usually available in the spec of the battery.
