Jul 12, 2024 4:26 PM UTC
STC3117 Missing battery detection
If the IC is powered by the battery, how does missing battery detection work ? I am working on a product which will have a USB interface and a single cell Li-Ion battery with charging circuit and a gas gauge. I need to take care of scenarios where the unit is connected over USB to a PC/Laptop but the battery is not connected. How does the firmware (running on an STM32) know that the battery is missing ?
AScha.3
Jul 12, 2024 5:17 PM UTC
So the stc checks, if battery away...
and firmware can check:
batt removed ...
thats it.
...or i dot understand your question.
Jul 12, 2024 5:19 PM UTC
How is the IC powered if the battery is not connected ?
AScha.3
Jul 12, 2024 5:37 PM UTC
If the battery is the only supply...not at all, so no problem. :)
cpu is dead , until power coming..
Jul 12, 2024 6:49 PM UTC
You tell us. Is it powered by USB as well, or only by the battery? Show the schematic if you can.
