Jul 16, 2024 2:50 PM UTC
STC3117 get Gas gauge charge data
I'm using the STC3100 chip to get the coulomb used from the battery, using the REG_CHARGE_LOW registers,
on the new board, I want to move to STC3117, but I don't see this register,
Does anyone know how I can get this value?
Shamir
Andrew Neil
Jul 16, 2024 2:58 PM UTC
What about REG_SOC ?
Jul 16, 2024 5:14 PM UTC
As I understand, this is % of the battery,
I can't get the "used" coulomb value.
Andrew Neil
Jul 16, 2024 5:30 PM UTC
But you can easily work that out from the battery % , surely?
Jul 17, 2024 12:20 PM UTC
Thanks for the replay,
I'm not sure I can get the coulomb reading in this mode,
it seems that I need to set the battery information in the chip, and the chip calculates the % which I get.
this is not what I need,
but, because of the footprint of the device, which requires the use of blind VIA which increases the board price - I will not use this chip, and use the SCT3100.
thanks a lot for the answers and help
Shamir
