alevinthal
Mar 23, 2010 4:27 PM UTC
Startup error for 12-pole BLDC motor using STM8-MCKIT
Posted on March 23, 2010 at 17:27
alevinthal
May 17, 2011 8:20 AM UTC
Posted on May 17, 2011 at 10:20
 I have read App note AN1276 and the issue does appears to be in the alignment ramp and startup ramp table. How can I compute the correct parameter/table values for these functions? What other parameters must I set to get the system working?
Gigi
if you have Startup fail error it means that the required numbers of valid BEMF zero crossing detection have not been occurred.
I suspect that you have to change the ramp-up acceleration to achieve the right control. To do this the best way is to use the STM8 MC Builder available at the following link
http://www.st.com/stonline/products/support/micro/files/stm8smcbuilder.zip
Another trivial issue: if the
motor
have 12 poles this means 6 poles pairs?
Ciao
Gigi
