terryhao
Aug 4, 2003 11:45 AM UTC
sT92141 run at 9Hz OK?
Posted on August 04, 2003 at 13:45
terryhao
terryhaoAuthor
May 17, 2011 8:16 AM UTC
Posted on May 17, 2011 at 10:16
Dear all,
I want to know if I can use ST92141 to run the Three phase motor stably under 9HZ?
Terry
maxime2399
Yes, it is possible.
It is also possible if you run only at low speed to use more steps for the sinewave, therefore to have beter precision.
