bhavin_shah10
speed information
  • January 30, 2004
  • 1439 views
Posted on January 30, 2004 at 11:57
speed information
gaetano
May 17, 2011
Posted on May 17, 2011 at 10:17
if I have well understood, you are looking for something that allow you to output from your system (ST72141) the data relative to speed?
But you don't specify if the output device is a monitor (to show them), a led display or another device.
Generally, the tachometer is used as sensor 'to input' the speed...
Please, clarify these points.
Regards,
Tanio
bhavin_shah10
hi i m using st72141.
How can i use i/o ports to supply my speed information to tachometer?
or what is other way that i can display my speed information.?
BK
