Request for Junction-to-Case Thermal Resistance (Rth(JC)) of STGAP2D
I am currently designing a SiC MOSFET gate driver circuit using the STGAP2D.
As part of the design process, I am performing thermal simulations to evaluate the temperature rise of each device.
Based on the simulated case temperatures, I estimate the junction temperatures to verify that sufficient thermal margin is available.
However, while the STGAP2D datasheet provides the junction-to-ambient thermal resistance, Rth(JA),
it does not specify the junction-to-case thermal resistance, Rth(JC).
Could you kindly provide the junction-to-case thermal resistance, Rth(JC), for the STGAP2D?
Alternatively, if another thermal parameter (such as ΨJT or a thermal model) is recommended for estimating junction temperature from the case temperature,
I would appreciate your guidance.
Thank you for your support.
