Blacbird
Aug 21, 2017 10:34 AM UTC
Remnants of stall detection in L6472 and L6482 datasheets
Posted on August 21, 2017 at 12:34
Hiho,
there are still remaining hints of stall/step loss detection (for example at the description of the FLAG pin) in the datasheets of the above mentioned ICs although they are only implemented in the L6480/L6470. That way we only realized that these features are not implemented after we were quite far into a project. Would it be possible to remove those references to avoid misunderstandings like this in the future?
Cheers,
Tobias of Blacbird Technologies
#stepper-driver
Enrico Poli
Aug 24, 2017 2:08 PM UTC
Posted on August 24, 2017 at 16:08
I'm sorry the error in the documentation led to this misunderstanding.
In the latest
http://www.st.com/content/ccc/resource/technical/document/datasheet/1e/f1/a3/3f/3e/49/44/02/DM00047136.pdf/files/DM00047136.pdf/jcr:content/translations/en.DM00047136.pdf
 published on our website (Rev 5) I found no references to the stall detection feature.
In the
http://www.st.com/content/ccc/resource/technical/document/datasheet/08/7b/6c/c9/3f/a5/43/7d/DM00067131.pdf/files/DM00067131.pdf/jcr:content/translations/en.DM00067131.pdf
one (Rev 6) there are still some references in the paragraphs dedicated to the blanking. They will be corrected in the next revision.
Thanks for your feedback
Blacbird
BlacbirdAuthor
Aug 29, 2017 4:24 PM UTC
Posted on August 29, 2017 at 16:24
Thanks for caring about this issue. In rev5 of the L6472 datasheet step loss is still mentioned as an alarm condition for the flag pin on page 18, but you are right, this should not lead to any misunderstanding.
Enrico Poli
Aug 31, 2017 10:00 AM UTC
Posted on August 31, 2017 at 10:00
Thanks, I'll add the error in L6472 datasheet - page 18 in the correction list.
