May 31, 2024 1:16 PM UTC
Real consumption of L476RG + sx1272
Hello as I am using Nucleo-L476RG and sx1272mb2DAS I want to mesure consumption with LPM01A. The probleme is when the consumption is very high because the part of Programmer is not isolated. Also the limitation of using an external source of power 3v3 I have to cut the board. Is there any other solution to see the real power consumption of the node.
