Oct 12, 2025 8:23 AM UTC
powerStep01 Active Position Tracking
Is there a way to read the motor position while it's moving, such as with a command like "run," "goto," "move," or any other command from the Powerstep01? Does the motor need to be stopped for the motor position to be read correctly? Currently, when I read while it's moving, I see very different values ​​appearing.
