paulpaul9153
Jul 10, 2017 3:33 PM UTC
Powerstep noise
Posted on July 10, 2017 at 17:33
Hi, i'm trying the powerstep board, with 1/16 step using advance current control, when the motor run there's no problem. But when the motor is stopped there's a little noise from the motor. The noise is greather when the motor is stopped in a micro-step position, and is less when the motor is stopped in a full-step position. Its this noise normal in the powerstep?
#powerstep01 #motor #noise
