Jan 7, 2026 1:47 PM UTC
Power Cycling Capability curves (Nf vs ΔT) for discrete SiC MOSFETs in TO-247 packages
Hello everyone,
I am currently working on a lifetime estimation for a SiC-based power converter design. I am specifically looking for Power Cycling Capability data for discrete SiC MOSFETs in TO-247 packages.
While power modules (like HybridPACK or EasyPACK) usually have well-documented Nf curves in their application notes, finding similar "to-failure" data for discrete SiC components is proving to be difficult.
I am looking for an analytical lifetime model for discrete SiC devices, ideally using the CIP2008 formula or a similar approach with clearly defined parameters.
Any insights, documentation, or links to technical papers would be greatly appreciated,
Best regards
Peter BENSCH
Peter BENSCHBest answer
Jan 22, 2026 12:08 PM UTC
Welcome @blaze22, to the community!
Since no one in the community has responded to your question yet, I assume that no other user will be able to help you. Perhaps it would be better to discuss the question with your local distributor, or alternatively with the colleagues at the personal Online Support OLS?
Good luck!
/Peter
Peter BENSCH
Good luck!
/Peter
