MMARI.1
Senior II
Jan 12, 2025 7:36 AM UTC
Power Backup by Super capacitor
hi ,
Aiming to have few minutes power  back up for  STM32 mcu with SD card incase main supply 5v goes OFF condition . Timer added for capacitor  charging time since initial current is will be little high .
The above is setup enough ? or something special circuit to be build for super capacitor ?
MHoll.2
Senior III
Jan 12, 2025 10:23 AM UTC
Normally this Supercap's have rather high ESR, so probably not a good idea. If You really need some minutes of backup you will need to do this with a battery, If you need only some 100's of ms then I would use some "normal" Capacitor, but be award that the STMPS2151 will only work down to about Vout + 0.5V.
MMARI.1
MMARI.1Author
Senior II
Jan 12, 2025 12:01 PM UTC
hi,
can you suggest 3.7v battery charger + battery switch  over  to main supply handling  IC number ?.
