Sep 6, 2023 11:39 AM UTC
PMIC for 24V with ASIL D SPI and watchdog
We need PMIC for Automotive application with 24V with SPI and watchdog with ASIL D
SU1Author
Sep 7, 2023 9:14 AM UTC
Kindly reply to the above PMIC requirement
Peter BENSCH
Sep 7, 2023 11:28 AM UTC
Welcome @SU1, to the community!
With your given parameters you can have a look at the following PMICs:
They can be operated with a VBAT of up to 32V. But you probably need a higher input voltage range because of the expected load dump tests, don't you?
/Peter
