Oct 19, 2024 7:02 AM UTC
PFC Controller for 2kW
I'm looking for a PFC controller for 2kW output,
Input - 90-265VAC
Output - 400VDC
which controller IC do you suggest for boost topology with the least BOM count?
AScha.3
Oct 19, 2024 7:15 AM UTC
depends at first: which mode you want : CCM or DCM ?
I use NCP1654 , ccm; and UCC38051 , dcm.
But the big problem is : to decide, which device can switch this power; and how to build the coil .
