MLeeu
May 9, 2019 9:15 AM UTC
Parallel operation of several EVALPWD13F60 kits
For a test application I require up to 8 A of current (although at a lower voltage), is it wise to use multiple of these evaluation boards in parallel. To prevent shoot-through, a small ferrite bead/inductor can be used in series with the driver, but is there anything I am missing?
