Oct 17, 2023 4:55 AM UTC
Operating temperature range of IC "STW4N150"
Can i know the minimum Operating temperature range of this IC "STW4N150"
Peter BENSCH
Peter BENSCHBest answer
Oct 18, 2023 1:01 PM UTC
Please note that the storage temperature must not be confused with the operating temperature and only refers to the storage of the device.
There is nothing to prevent operation at -30°C if the applicable parameters of the data sheet are observed.
Peter BENSCH
Oct 17, 2023 7:45 AM UTC
Welcome @Pradeep2014, to the community!
you can use the STW4N150 down to -40°C, the data sheet also shows some graphs for -50°C.
Hope that helps?
/Peter
Oct 17, 2023 9:52 AM UTC
Thanks for the reply,
But the datasheet says that it has a operating temperature of max +150 and storage temperature has -55 to 150.
Can we operate in negative temperature "-30"?
Peter BENSCH
