JackyCheung
Aug 19, 2017 11:34 AM UTC
OPEN_LOOP_VOLTAGE_d parameter
Posted on August 19, 2017 at 13:34
debugging motor in open loop mode
#define OPEN_LOOP_VOLTAGE_d   6000    /*! < Three Phase voltage amplitude  in s16 format */
  1. What is the formula for the value of
    If I want to output a fixed voltage value, how to determine the S16 value
   PhaseVoltage(V) = [PhaseVoltage(s16V) * Vbus(V)] /[sqrt(3)*32767].
If I want to output a fixed voltage value, how to determine the S16 value?
Enrico Poli
Aug 24, 2017 1:50 PM UTC
Posted on August 24, 2017 at 15:50
I think the value is defined as duty-cycle of the PWM applied to the motor in a 16 bit format.
0 --> 0 % of duty-cycle --> no voltage applied
65535 --> 100 % of duty-cycle --> 100% of the bus voltage applied to the motor
6000 --> 6000/65535 = 0.0915 = 9.15 % of duty-cycle --> about 9% of the bus voltage is applied to the motor
You can easily check it with an oscilloscope
JackyCheung
Aug 24, 2017 4:47 PM UTC
Posted on August 24, 2017 at 16:47
I tested, S16V maximum is 32767, but how can not calculate
Enrico Poli
Aug 25, 2017 3:43 PM UTC
Posted on August 25, 2017 at 15:43
Ok, so you already have the answer.
Vphase = Vbus*OPEN_LOOP_VOLTAGE_d/32767
This will be the peak value of the the sinusoidal voltage applied to the motor.
