Visitor
Nucle programming a STUSB4500 using STUSB4500_GUI_2.00 fails to detect STUSB4500, but hwultility does
When I try to connect to my STUSB4500 using STUSB4500_GUI_2.00 with a Nucleo-F073RB it sees the COM4: port, but after clicking OK I always get the message
I2C Read error. Error number: -2 (0xFFFFFFFE)
HWchecktutility does recognize the STUSB4500 as a i2c device:
Nucleo Hardware Check Utility - K2k (c) [G.G] <v1.0.2.31440>
Available COM Ports = 1: | COM4 |
Port: COM4 opening: OK closing: OK
Testing Ports: [1]: | COM4 |
Testing COM4 :
try-1: >>OK Target replied in (ms):11,85
try-2: >>OK Target replied in (ms):15,43
try-3: >>OK Target replied in (ms):15,51
try-4: >>OK Target replied in (ms):15,78
try-5: >>OK Target replied in (ms):14,79
=> There is 1 target connected on: [COM4 ]
Speed test:
Sending_Data1024: time=222 ms, >Transfer_speed =75531,53 bit/s
Sending_Data1024: time=230 ms, >Transfer_speed =72904,34 bit/s
Sending_Data1024: time=235 ms, >Transfer_speed =71353,2 bit/s
->Selected COM4 Testing replies...
COM4: Target OK
Ping Ok
Firmware version: 1.05.190522
Serial number : ST-vl022D
----Scan all devices
BusCount: 2
I2C_Scan - bus 1: [OK]
Devices found: 2
Addr found (8bit): 0x50 0x51
(7bit): 0x28 0x28
I2C_Scan - bus 2: ERROR 999.
Summary: > Attached ports Detected -> COM4
> Ports with I2C devices -> COM4
My logic analyzer sees correct responses to the device scan (see attachement).
I installed the VC_redist.x86.exe
I tried:
  • STUSB4500_GUI_2.00 (using Nucleo_F072RB_STUSB_UART_NVM_config_1.05.bin FW)
  • STUSB4500_GUI_1.11 (using Nucleo_F072RB_STUSB_UART_NVM_config_1.04.bin FW)
  • STUSB4500_GUI_1.09 (using Nucleo_F072RB_STUSB_UART_NVM_config_1.04.bin FW)
But the error keeps coming back.
How can I program my STUSB4500 using a Nucleo-F073RB?
