rimbaud
Jul 11, 2019 10:02 AM UTC
Need level shifter for LSM303AH
I am work with LSM303AH which working normally with 1.8 v.
My MCU works and provide 3.3v only.
I am looking for level shifter 3.3v to 1.8 v and vice-versa, for powering, I2C communication and logic high conversion.
Do you have any device to suggest ?
regards
Uwe Bonnes
Chief
Jul 11, 2019 12:42 PM UTC
PCA9306 ,TCA9506?
rimbaud
rimbaudAuthor
Jul 11, 2019 1:54 PM UTC
Thank you ,PCA9306 seems be good deal.
But how i can shift high and low level of INT_MAG/DRDY (high level 1.8 v -> 3.3v )?
regards,
Uwe Bonnes
Chief
Jul 11, 2019 2:19 PM UTC
SN74LVC1T45? Or with INT_MAP pulled to 1.8V with a resistor and driving the base of an NPN
rimbaud
rimbaudAuthor
Jul 11, 2019 3:39 PM UTC
Can you suggest me a resistance value please for the base (for 1.8 v) ?
regards,
rimbaud
rimbaudAuthor
Jul 11, 2019 3:50 PM UTC
Do you suggest me BCP56-16 transistor ?
regards,
Uwe Bonnes
Chief
Jul 11, 2019 4:07 PM UTC
BCP56-16 seems oversized. If you have problems with dimensioning an transistor inverter, either read some books (AOE, Tietze Schenk) to learn the basics or stay with the 74T45.
rimbaud
rimbaudAuthor
Jul 12, 2019 3:47 PM UTC
Thank you for for suggestions.
What do you think about this device BOB-11771 ?
With 4*4 input*output, i can shift the SCL and SDA an other pins.
regards,
Uwe Bonnes
Chief
Jul 12, 2019 4:28 PM UTC
 AUTO-DIRECTION SENSING devices are sensible parts. Reflection on open wires can upset them. It may work, if you know what you are doing and do things in s sensible way, but expect problems in corner cases. Dedicated I2C level shifts will work in a wider range of setups.
Uwe Bonnes
Chief
Jul 12, 2019 5:14 PM UTC
As some user stated: "whereas for open-drain signals such as I2C, the BOB-12009 is a better option"
rimbaud
rimbaudAuthor
Jul 15, 2019 1:43 PM UTC
Thank you for your support @Uwe Bonnes​
This seems is a good deal my case.
just an extra question out of scope. Can i hide the name of my entreprise in the title ?
regards
