PX.2
Apr 12, 2021 9:15 AM UTC
Motor Control configuration for DRV8323 driver
I am working on BLDC motor driver. I am use STM32G431 as control unit with Motor Control Workbench and DRV8323RH gate driver. I have problem with getting the motor to spin, as soon i I start it, i am getting under voltage error. And see some overcurrent problem at power stage. It happent both in 3 and 6 PWM control mode.
It seems like it is software control issue. Does anyone have expierience with Motor Contron on Texas DRV83xx drivers?
    uomo motore
    Apr 19, 2021 5:20 AM UTC
    Please ensure that the PWM channels are connected correctly (TIM1_CH1 to INHA, TIM1_CH1N to INLA, TIM1_CH2 to INHB and so on). Please verify that the Power Stage>Driving Signal Polarity for high side and low side is set correctly.
    Feb 8, 2024 4:57 AM UTC
    how did you make it work?
