Johan Portier
Mar 13, 2018 5:21 PM UTC
mosfet stp5nk50z
Posted on March 13, 2018 at 18:21
Hello
I am looking for an equivalent of the mosfet stp5nk50z to 220  for a Rolling shutter, thank you
T J
Senior III
Mar 14, 2018 11:03 AM UTC
Posted on March 14, 2018 at 12:03
why ?
best to use the right part.
https://www.digikey.com/products/en?keywords=stp5nk50z
if you need a better unit we can work on that.
Johan Portier
Mar 14, 2018 5:36 PM UTC
Posted on March 14, 2018 at 17:36
This component is hs and it is no longer available except the Stp5nk50zfp new to electronics, I need to know if it can be mounted instead
Thank you
T J
Senior III
Mar 15, 2018 12:44 AM UTC
Posted on March 15, 2018 at 00:44
The Z part is available and the ZFP part is available but not recommmended for new designs.
yes either part can be used,
however on the ZFP part the tab is not conductive.
check if the PCB has the TAB connected to pin 2.
if the PCB has this connection, either part can be used.
T J
Senior III
Mar 15, 2018 10:25 PM UTC
Posted on March 15, 2018 at 23:25
I gave you the link above,
it has both parts available.
