info51
Nov 15, 2004 10:47 AM UTC
MCES PORT ON ST72141
Posted on November 15, 2004 at 11:47
gaetano
May 17, 2011 8:17 AM UTC
Posted on May 17, 2011 at 10:17
Ciao Claudio,
effectively when an MCES event occurs the MOE bit is put to zero causing all the actions you listed.
But, even if the MCES pin goes high again (normal operating mode), you have to write the MOE bit to 1 if you want to enable your micro output. In other words the MOE bit is not linked directly to the MCES pin.
I hope this helps you.
With my best regards,
Tanio
info51
info51Author
I wish understand something more on Mces port in the ST72141.
the utility of this port is only to get a low level from driver (es. diag signal from the L6386) ?
when we get this low level on Mces happens:
Moe bit reset
output Mco0-Mco5 put in Hiz
interrupt EI if set EIM ?
this setting depend even on the Mces level ?
I mean, when the Mces level return high again, the Moe bit will be set, and the output abilitate directly?
regards
thank you for help
Claudio
