bille.stello
May 17, 2011 8:20 AM UTC
Posted on May 17, 2011 at 10:20
your corresponding AC mains should be 24/sqrt(2).
By the way, I would suggest you to download the STM32 Field-Oriented Control GUI from
http://www.st.com/mcu/modules.php?name=mcu&file=familiesdocs&fam=110&doc=59
Using this Graphical user interface it will be much easier configuring the STM32 PMSM Motor Control library.
Regards,
Billino
bille.stello
there are no GUIs supporting the FW library 1.0 (you should use excel file and manually edit the parameters file for that). If you bought the STM32MC-KIT we can try to separately let you have the MC FW library v2.0
Regards,
Billimo
reman130488
thanks MR. Billino..
my stater kit library is versi 1. i want seacrh GUI versi 1 too, bt i not found it..T_T
reman130488
my lecture bought STM32-MCKIT from ST and now i'm doing last project with STM32-MCKIT, but my lecture don't know how to configure that starter kit. maybe Mr. Billino can help me to configure that starter kit with sensorless control?that starter kit use FW versi 1...
