poole
May 23, 2007 9:52 PM UTC
Max rpm for a 29v BLDC motor
Posted on May 23, 2007 at 23:52
poole
pooleAuthor
May 17, 2011 8:14 AM UTC
Posted on May 17, 2011 at 10:14
Hi Gigi,
Thanks for your help. I have a motor with only 1 pole pair. So it looks like the maximum RPM = 680Hz * 60 / 1 = 40800 (is there any way to increase this?)
Hopefully this will be sufficient!
Thanks again!
Kel
poole
pooleAuthor
Hi!
I am trying to run a 29v BLDC motor at 50,000rpm in either open or closed loop mode. I have read the threads relating to maximum speeds, and also application notes. However, I am still a little confused about how to calculate this.
Any help, or pointing to further documentation would be great!
Thanks,
Kel
poole
pooleAuthor
Hi gforte,
Thanks again for your help!
I will see if 40800RPM is fast enough, and will try modifying the settings if it's not. I'll let you know how it goes.
Thanks so much!
Kel
