Feb 10, 2025 10:19 AM UTC
Looking for an L9963E C STM32 Library
Hi everyone,
I'm currently working on a project where I need to interface an STM32 with the L9963E BMS IC from ST. Before developing my own driver, I wanted to check if anyone has already written a C library for this IC and would be willing to share it or provide some guidance.
If you have experience with the L9963E and have developed a driver, I'd appreciate any insights, code references, or suggestions you can provide.
Thanks in advance!
antonio_caponeBest answer
Feb 18, 2025 5:12 PM UTC
I’m closing this thread as I’ve decided to develop my own open-source driver, that will be accessible from https://github.com/antoniocapone/l9963-open . For reference, there is also an existing driver that supports the use of the L9963T transceiver (and for now it works only with the transceiver), https://github.com/squadracorsepolito/L9963E_lib.
Special thanks to every people that answered to my question.
Andrew Neil
Feb 10, 2025 10:22 AM UTC
Feb 10, 2025 10:39 AM UTC
Hi Andrew,
I have already seen this page. The evaluation board's firmware source code is not provided.
Peter BENSCH
Feb 14, 2025 9:34 AM UTC
The L9963E is an automotive device whose software is usually only available from your local distributor or STMicroelectronics office.
Hope that helps?
/Peter
antonio_caponeAuthorBest answer
