Nov 6, 2023 6:47 AM UTC
LED Driver Design using EVL012LED, STNRG012, SRK2001
In Design of LED Driver using EVAL012LED 200W power supply. Output Voltage of EV B is 56V, but requirement is 24V for LED STRIP Load and had made changes in EV B to get the 24V at output side.  Dimming Voltage is at DIM 1 pin in schematic, at 100mV Dimming Voltage and less than that output current is becoming constant.
