Mar 28, 2025 10:58 AM UTC
LDO29300P2MTR
We have implemented the following circuit. This matches the application circuit given in datasheet of LDO29300P2MTR.But it does not yield expected output. We need help!!IMG20250328160749.jpg
saranBest answer
Mar 29, 2025 4:05 AM UTC
@Andrew Neil
I have attached the images for your reference. Kindly let me know if I have made any mistakes
WhatsApp Image 2025-03-29 at 9.11.29 AM.jpegWhatsApp Image 2025-03-29 at 9.23.29 AM.jpegWhatsApp Image 2025-03-29 at 9.27.10 AM.jpeg
Andrew Neil
Mar 28, 2025 11:18 AM UTC
@saran wrote:
 it does not yield expected output. !!
So what output does it yield ?
@saran wrote:
What is the significance of the 5.41A there?
The LD29300 is only a 3A regulator ...
https://www.st.com/en/power-management/ld29300.html
Not quite:
You've left the INH pin open.
saranAuthor
Mar 28, 2025 11:50 AM UTC
The IC takes an input voltage of 24V/5.4A , expected output is 12V BUT IT GIVES 0V . Also where should I connect the INH pin.
Andrew Neil
Mar 28, 2025 11:58 AM UTC
The IC takes an input voltage; the current is determined by the load.
@saran wrote:
expected output is 12V BUT IT GIVES 0V . .
The output depends on R1 - so what do you have that set to?
As the datasheet shows - connect it high for 'ON', or low for 'OFF':
Peter BENSCH
Mar 28, 2025 11:56 AM UTC
+1
And for an output voltage of 12V that can be set within narrower limits, I would replace VR1 with 1k and connect an 8.2k resistor in series to VR1. The output voltage should then be adjustable between approx. 11.2V-12.6V.
saranAuthor
Mar 28, 2025 12:03 PM UTC
@Andrew Neil
R1 value is 10Kohm ; R2 is 1Kohm
saranAuthor
Mar 28, 2025 12:28 PM UTC
@Peter BENSCH
I have shorted pin 1 and pin 2. Still, the output is 0V. If you have any sample circuits for the LDO29300P2MTR, kindly help me solve the issues.
Andrew Neil
Mar 28, 2025 1:09 PM UTC
Then check your resistors & wiring.
Perhaps show a good, clear photograph of your setup.
saranAuthorBest answer
@Andrew Neil
saranAuthor
Mar 29, 2025 4:57 AM UTC
@Andrew Neil
The chip gives expected output 12V but within a fraction of second , voltage drops to 0V.
saranAuthor
Mar 29, 2025 11:25 AM UTC
@Andrew Neil
@Peter BENSCH
Thanks for the help. LD29300P2MTR will work on 2.5 V to 14V only. it will never work greater than 14V. We can use the MIC29302WU
Thanks &Regards,
Saravanan G
Peter BENSCH
Mar 29, 2025 7:55 PM UTC
Sorry, I had also overlooked this during a cursory glance at the data sheet: although the LD29300 can withstand an input voltage of up to 30V, it actually only works up to 14V. This can be found in the data sheet as footnote 1 under table 2:
Above 14 V the device is automatically in shutdown.
/Peter
Andrew Neil
Mar 31, 2025 8:42 AM UTC
So it does!
@saran - here:
@saran - always important to understand that these "Absolute Maximum" ratings are not operating specs!
