Sep 29, 2023 10:46 AM UTC
LDL212PUR bypass capacitor requirements
Hi all. The data sheet for the LDL212PUR low dropout linear regulator does nor specify the quality of the input and output bypass capacitors with regard to ESR or loss tangent requirements.  Most LDO regulators require at least one low ESR bypass capacitor, usually on the output side.  This data sheet does not specify that parameter on any of the bypass capacitors.  Any recommendations?
Thanks - SteveD
JFran.13
JFran.13Best answer
Apr 15, 2024 1:55 PM UTC
Any luck?
I'm selecting LDOs for a few projects but I can't understand how stable it's going to be with ultra low esr ceramic caps. I have this https://product.samsungsem.com/mlcc/CL10A226MO7JZN.do operating at 5V on the output and the same one in CIN for 6-8.4V.
JFran.13
JFran.13Best answer
Any luck?
SteveDAuthor
Apr 15, 2024 7:41 PM UTC
Thanks for the info.  It would be good though if the data sheet listed the required characteristics of the input and output caps
