Oct 19, 2023 10:54 AM UTC
Label format
I have Part number STD10P6F6, I received these parts with a ST micro label on them. This label holds the trace code and at the bottom of the label it says LOT, Followed by a code. I assume that is the lot code for the parts, can you please clarify this for me? Also what is the difference between the trace code and lot?
