igamoso
Jul 15, 2022 3:16 AM UTC
L99DZ100GTR Marking Information
Dear Support,
Please help to share marking information for the part number L99DZ100GTR?
The marking info in the datasheet do not show the date code.
    Peter BENSCH
    Peter BENSCHBest answer
    Jul 15, 2022 7:11 AM UTC
    The date code is as usual: three characters in the middle on the right mean YWW, i.e. last digit of the year and calendar week.
    This date code should also be found on the bag label.
    Does it answer your question?
    /Peter
    Peter BENSCH
    /Peter
    igamoso
    igamosoAuthor
    Jul 15, 2022 7:38 AM UTC
    thank you and noted on this.
    Peter BENSCH
    Jul 15, 2022 8:09 AM UTC
    You're welcome!
    If the problem is resolved, please mark this topic as answered by selecting Select as best. As you know this will help other users find that answer faster.
    Thank you and regards
    /Peter
    igamoso
    igamosoAuthor
    Aug 24, 2022 8:04 AM UTC
    Hi Peter,
    Please confirm if the full marking of the "E3" version is correct for L99DZ100GTR.
    igamoso
    igamosoAuthor
    Aug 24, 2022 8:07 AM UTC
    Hi Peter,
    Can you provide datasheet related to e3 version's full marking? And why is there no datasheet for e3 marking on the Internet?
    Peter BENSCH
    Aug 25, 2022 1:34 PM UTC
    The e3 marking is in accordance with the standard IPC/JEDEC J-STD-609. It uses the JEDEC Pb-Free Category e3 logo because e3 stands for surface coating with tin (Sn).
    /Peter
