May 1, 2026 11:26 PM UTC
L9961 Cell voltages deviate during discharge
Hello, we are having an issue where our cell voltage readings are drifting when discharging. When there is no current, the voltages all read correctly. However, during discharge, we see that cell 5 and cell 1 have lower voltage readings by about 150mV at 5A. Once discharge is ended, the voltages level off again. I have checked that this is reflected in the registers.
These are our filter settings:
Peter BENSCH
Peter BENSCHBest answer
May 4, 2026 11:53 AM UTC
Based on the L9961 data sheet, the behaviour is likely related to the measurement timing and input filter settling under load, rather than a pure ADC accuracy issue.
A few key points:
  • The cell measurements are taken cyclically, not continuously
  • Your T​MEAS_CYCLE = 50ms must be longer than thefull measurement task duration
  • With TCELL_FILTER = 16.67ms, the task may be too close to the cycle time, which can cause unstable or skewed readings during discharge
  • The 150mV shift at 5A is much larger than the device’s specified cell measurement error, so I suspect a dynamic settling / layout / sense path effect
Recommendations:
  • Increase TMEAS_CYCLE to ensure it is safely greater than the total conversion time
  • Temporarily reduce the cell filter time and check whether the drift decreases
  • Compare the L9961 readings with a direct measurement at the cell terminals under load
  • Check whether cell 1 and 5 have any layout or routing asymmetry, especially around the sense filters and references
/Peter
Peter BENSCH
A few key points:
Recommendations:
/Peter
