Dec 31, 2024 8:21 AM UTC
L9788 Marking is 0D273, is it correct?
Please see the label photos and product MARKING AREA
Is this the original?
Peter BENSCH
Peter BENSCHBest answer
Jan 2, 2025 10:26 AM UTC
Welcome @SMO8765, to the community!
The worldwide community is a place for mutual help between users of devices from STMicroelectronics. Since your question is not a general technical question, it would be better addressed to the personal Online Support OLS.
But I can answer you the following:
  1. L9788TR indeed has the marking 0D273.
  2. The above-mentioned OLS can determine whether the goods are original if the labels are intact and legible. Since in your case both the Bulk ID and the Trace Code have been made partially illegible, this is no longer possible. Therefore, please contact the source of your devices, as they are the only ones who can provide information on this - if they want to at all.
Good luck!
/Peter
Peter BENSCH
Good luck!
/Peter
SMO8765Author
Jan 3, 2025 1:44 AM UTC
OK,thank you
