Mar 24, 2025 10:14 AM UTC
[L9369] Reg 6Fh D[1] =0 to set Low ohmic path to be connected or disconnected?
Register 6Fh, D[1] SPI_HSoff_high
Low ohmic path switch off disable bit for HS pre-driver stage A and B
0 / R/W (default) (‘1’ = low ohmic path enabled)
When D[1] =0,  Low ohmic path between HS driver GHy_x and SHy_x is connected or disconnected?
When H-bridge output to driver motor running,   should Low ohmic path be connected?
Thanks!
Billy OWEN
Mar 27, 2025 3:22 PM UTC
Hi @haihun
This post has been escalated to the ST Online Support Team for additional assistance.  We'll contact you directly.
Regards,
Billy
