PZha.1
Mar 8, 2023 3:32 PM UTC
L7987 and L7987L substitued parts
HI Sir,
we have applied L7987 and L7987L on our touch display computer,
we don't have enough stock for now
is there any substitued parts available
thanks�?
With best regards,
PZ​
    Peter BENSCH
    Peter BENSCHBest answer
    Mar 9, 2023 8:35 AM UTC
    The A7987 is functionally identical to the L7987. However, it is more expensive because of the automotive approval, so I did not consider it. If you accept the higher price, you can of course also use the A7987.
    /Peter
    Peter BENSCH
    Mar 8, 2023 8:25 PM UTC
    The L7987 (3A) and L7987L (2A) can be used up to 61V input voltage and unfortunately do not have an alternative type.
    If the problem is solved, please mark this thread as answered by selecting Select as best, as also explained here. This will help other users find that answer faster.
    /Peter
    PZha.1
    PZha.1Author
    Sep 25, 2023 10:29 AM UTC
    HI Peter,
    could you please advise that how to select the resistors for the voltage setting,
    are the resistor volume same for L7987, L7987L and A7987 voltage setting.
    thanks.
    with best regards,
    PZha
    PZha.1
    PZha.1Author
    Sep 25, 2023 10:41 AM UTC
    for example: output 5V,
    60.4K and 11K,=5.19V
    43K and 8.2K =4.99V
    6.04K and 1.1K=5.19V
    3K and 0.56K=5.08V
    which one is more suitable. any difference
    PZha.1
    PZha.1Author
    Mar 8, 2023 8:30 PM UTC
    Hi Sir,
    can we use A7987 as alternative.
    thanks!
    PZ
    Peter BENSCH
    /Peter
    PZha.1
    PZha.1Author
    Mar 11, 2023 11:37 AM UTC
    HI Peter,
    thanks for your conformation.
    with best regards,
    PZ
    Peter BENSCH
    Mar 13, 2023 11:52 PM UTC
    Great!
    Good luck!
    /Peter
