pdelmer
May 17, 2011 8:16 AM UTC
Posted on May 17, 2011 at 10:16
The Evalboard is availble through your local Distributor (Silverstar in Italy). The Order Code should be the EVAL6208. Attached you´ll find an Application Note for implementing Microstepping with the L6208 and also the scematics.
the_vice1304
Hi folks,
where can i look for the L6208 eval kit ? (from ST ? =) )
i tried L6208 driver in dip format on a prototype board .... i burned 2 IC
so please help me to find it !
I'd like to use it for driving stepper motors in microstepping mode ....
