TYOSH.1
Aug 26, 2020 12:37 AM UTC
L6206Q Charge pump circuit.
In the L6206Q data sheet "Figure 5. Charge pump circuit", AN1762 APPLICATION NOTE "Figure 9. Charge Pump", UM1925 User manual "Figure 11: X-NUCLEO-IHM04A1 circuit schematic", the connection order of Rp and Cp is different. ..
In actual operation, the connection order of R/C does not seem to matter so much, but is there a recommended circuit (connection order of Rp and Cp)?
Peter BENSCH
Peter BENSCHBest answer
Aug 26, 2020 8:28 AM UTC
With a serial connection of passive parts such as resistors, capacitors or inductors, the order of these parts is absolutely irrelevant. Therefore, Rp and Cp can be connected in either order without changing the behavior of the circuit at all.
Does it answer your question?
/Peter
Peter BENSCH
/Peter
TYOSH.1
TYOSH.1Author
Aug 26, 2020 11:08 PM UTC
Peter,
Thank you for your reply.
I understand that the order of connecting parts is irrelevant.
Best Regards,
Toshiyuki Yoshizawa
