musthafafarhan
Dec 16, 2015 3:14 AM UTC
L298n - Dual Brindge Driver - multiwatt 15: Why Sense a and Sense B ?
Posted on December 16, 2015 at 04:14
what purpose having Current Sense A and Current Sense B pins in L298 ? does it mean we can monitor the current of the motor using shunt resistor ?
Thank you for your answers.
#dc-motor-control #bldc-motor-control #l298
re.wolff9
Senior
Dec 19, 2015 10:08 AM UTC
Posted on December 19, 2015 at 11:08
The L298 is a dual H-bridge. With SenseA you can sense the current through one H bridge, while with SenseB you can sense the other. This would allow you to use 1 or two sense resistors, but not three like usually in a BLDC configuration.
